We're exhibiting at IMTS 2026 — Booth #134034, Sept 14–19. Come see us in Chicago.
GD&T is supposed to create a shared language between engineering, manufacturing, and inspection. But plenty of companies invest in training and still end up with confusion on the shop floor, disagreements during inspection, and engineers frustrated that their intent is still being misinterpreted.
Usually, the problem is not the training itself. It is that departments were trained separately.
Engineering goes through fundamentals first. Quality gets trained months later. Manufacturing may never get trained at all. Each group learns GD&T in isolation, applies it in isolation, and then everyone wonders why collaboration still feels painful.
There is a better approach: mixed-department training. It is one of the biggest differences between GD&T training that actually changes how teams work and training that does not.
team training - employees in a circle holding gears
What "On the Same Page" Actually Means
It doesn't mean everyone needs to be a GD&T expert. Inspectors don't need to design parts. Engineers don't need to run CMMs. But everyone does need the same foundational understanding of what GD&T is trying to communicate and how to interpret it correctly. That changes everything.
An inspector can have a productive conversation with engineering instead of saying, "I don't understand this callout."
A machinist can look at a datum scheme and understand how the part should actually be fixtured.
Quality and engineering stop arguing about what the designer "meant" because everyone is interpreting the print from the same baseline.
That's a different kind of team than most companies have, and it starts with how they were trained.
Why Separate Training Fails
Most companies train departments separately, and by the time everyone has gone through training, the damage is already done.
Engineering has developed habits. Quality learned the standard in isolation. Manufacturing built their own interpretations based on experience.
Technically, everyone "knows GD&T." But they don't understand it the same way. And that's where miscommunication starts.
Team around a table discussing a drawing
What Actually Happens When You Train Together
When engineering, machining, and inspection are in the same room, the conversations become just as valuable as the course material itself.
Here's what that looks like in practice.
A position tolerance for a pattern of holes is referenced to three datums, controlling all six degrees of freedom. The designer did their job. Manufacturing has dialed in their fixturing and CNC program to be efficient and consistent. Quality has built a CMM alignment that gives them repeatable results, and they even consulted manufacturing to make sure they were in agreement.
Nobody believes they are doing anything wrong.
But here's what nobody caught: the datum reference frame wasn't functionally correct, creating tolerance stackups. Manufacturing built a fixture that allowed their CNC program to establish its zeros off convenient features, but not functional ones. Quality built their CMM alignment to verify results based on manufacturing's process, not the drawing.
Every department made reasonable decisions, but none of those decisions were ever made together.
In a mixed-department session, all three groups are in the room when this comes up. Engineering explains what they intended. Manufacturing explains how they've been fixturing. Quality explains how they've been aligning their measurements. Collectively, they can focus on a solution that produces a good functional part, because that's the common goal that gets forgotten when departments work in isolation.
What Usually Gets in the Way
"It's too hard to get everyone in the same room."
Scheduling three departments is harder than scheduling one. But weigh that against the time already spent debating drawings, revising prints, and resolving interpretation issues. The coordination effort may be worth it.
"The training won't be relevant to everyone."
This assumes GD&T means something different for each department. It doesn't.
Engineering, machining, and inspection all need to understand the same standard. They just apply it differently. When teams learn together, they gain more than technical knowledge. They understand how their decisions affect the rest of the process, from design to manufacturing to inspection.
" Cross-department discussions usually turn into conflict."
That is exactly why the instructor matters. A good instructor keeps the discussion productive and grounded in the standard, not personal opinions or department politics.
When quality raises an inspection issue, the instructor clarifies the interpretation. When manufacturing pushes back on a tolerance, the instructor helps determine whether the issue is the tolerance itself or how the print is being interpreted.
The goal is not to “win” the argument. It’s to get everyone aligned on the same understanding.
Mixed department training - three employees looking at a drawing
How to Make Mixed-Department Training Work
  1. Pick your champions from each department. You don't need everyone in the room. Choose 2–4 people from engineering, machining, and inspection. The ones others go to with questions.
  2. Bring real drawings. Identify prints that are actively causing problems and give them to the instructor ahead of time. Use them as examples so discussions stay grounded in actual work.
  3. Encourage debate. This isn't a lecture. It's a working session where departments can raise concerns, challenge assumptions, and hash out interpretations together.
  4. Establish the baseline before anyone runs ahead. Don't have engineering applying GD&T for months before everyone else understands what they're looking at.
  5. Follow up. Bring the same groups back together 3–6 months later. Find out what's working, what's still breaking down, and address it before confusion becomes habit.
The Difference It Makes
When teams understand GD&T the same way, the results are concrete:
  • Fewer print revisions
  • Faster issue resolution
  • Better supplier communication
  • Less scrap and rework
  • Stronger collaboration between departments — including smoother company-wide GD&T rollouts
Those aren't soft benefits. They directly affect quality, efficiency, cost, and lead time.
The Bottom Line
Training departments separately is the path of least resistance. It's easier to schedule, easier to coordinate, easier to execute. But it's also less effective.
When engineering learns GD&T in isolation, they apply it in isolation. When quality learns separately, they interpret it separately. When manufacturing is left out entirely, they're guessing.
Mixed-department training takes more coordination upfront. But it is one of the few approaches that actually turns GD&T into what it was supposed to be in the first place: a shared language.
If you're thinking through GD&T training for your team, we're happy to talk through what makes sense for your situation. Who should be in the room, what level to start at, and how to structure it for your group.
