In this Question Line video, Jason answers the following question regarding reference dimensions on true position:Â Â
If a diameter is reference () on the drawing, does that make the GD&T under the diameter callout reference as well?
To answer this question, Jason walks through the above example assembly drawing to explain the scenario where a feature being controlled by position must have a reference size dimension rather than a tolerance on the size of the feature. Â
Got GD&T questions? Submit your questions to our GD&T experts at the link below! Â
https://www.gdandtbasics.com/share-your-gdt-questions/Â
Â
* If you are a current student, reach out to us directly and we will get you into contact with your instructor. Active students’ questions receive a direct response within 24-48 hours.Â
