In this Question Line video, Jason answers the following question, tackling a common source of confusion in GD&T—the difference between circularity and runout:
I work in a wheel workshop and regularly measure wheel treads. I am currently trying to fully understand how roundness works according to GD&T and how it should be evaluated in practice.
The person submitting this question explains that he is determining roundness by rotating an axially fixed wheel and using a dial indicator to measure the total variation. He wants to know whether this method correctly measures circularity according to GD&T standards.Â
Jason explains why this approach is actually measuring circular runout, not circularity (commonly referred to as roundness). Though circular runout and circularity are related concepts, they are not the same: one is measured relative to a datum axis, while the other is independent of any datum feature.Â
Using animations, Jason walks through the differences between the two and shows how each tolerance is correctly evaluated.
Do you have a GD&T question for us? Submit it at the link below: Â
https://www.gdandtbasics.com/share-your-gdt-questions/      Â
If your question is selected, we will notify you when our video answer is posted to our YouTube channel.      Â
* If you are a current student, reach out to us directly and we will get you into contact with your instructor. Active students’ questions receive a direct response within 24-48 hours.      Â
