Most professionals learn GD&T informally. They pick it up through past drawings, tribal knowledge, software defaults, and on-the-job problem solving. Over time, they become very comfortable with specific symbols, rules, and interpretations they see regularly.
What often doesn’t happen is a full, structured introduction to the GD&T system as defined by the standard. That means many people are fluent in a subset of GD&T without realizing how much of the language they’ve never encountered.
If you’ve never been taught certain symbols, modifier rules, or datum principles, you don’t know that knowledge is missing. And because work continues to get done, those gaps can remain invisible for years.
This is where the phrase “you don’t know what you don’t know” becomes especially relevant—not as an insult, but as a description of how partial knowledge works.
What Our Quiz Is Designed to Reveal
Our GD&T assessment quiz is best viewed as a diagnostic tool. It shows which concepts are well understood and which ones may need reinforcement, or even introduction. That information makes it possible to choose the right training and address gaps directly, rather than working around them.
The quiz is not intended to trick people or diminish their experience. Its purpose is to provide an objective snapshot of someone’s familiarity with core GD&T concepts typically covered in a fundamentals course. These are core concepts that we regularly see as the root of most issues in manufacturing, whether people realize it or not.
The quiz touches on topics such as feature control frames, datum reference frames, material condition modifiers, common GD&T symbols, and the foundational rules that make the system function. These are not advanced or niche topics; they are essential for correctly interpreting and applying GD&T.
When someone with many years of experience struggles with the quiz, it usually points to one of two situations.
  • They have developed strong practical skills within a limited scope of GD&T exposure
  • They have unknowingly relied on assumptions and shortcuts that were never corrected because “things worked well enough.”
In both cases, the underlying issue is the same: important parts of the standard were never fully learned.
Why the Results Can Feel Personal
Failing or underperforming on a quiz after years in the industry can feel uncomfortable. It may seem as though experience is being questioned or discounted.
That’s not the intent.
Experience has real value, especially when it comes to practical decision-making and problem-solving. The quiz simply highlights where experience alone may not have provided full coverage of the standard. Those blind spots exist not because someone did something wrong, but because they were never given the opportunity to learn the full system.
Moving Forward with Clarity
After taking the quiz, there are two paths forward. One is to dismiss the results and continue relying on the same assumptions and partial knowledge. The other is to use the information as a starting point to build a stronger, more complete understanding of GD&T.
When people take the second path, the results are tangible. They stop guessing, communicate more clearly across teams, interpret unfamiliar drawings with confidence, and pass on accurate information to others.
The quiz isn’t meant to tell you who you are as a professional. It’s meant to show you where you are, so you can decide where to go next.
