When quality issues start piling up or new engineers struggle to apply GD&T on real drawings, the default response is simple: send them to training.
But here’s what happens more often than anyone wants to admit. They come back from training and still hesitate when it’s time to apply it.
They know the symbols. They’ve seen the rules. But put them in front of an actual drawing, and the confidence just isn’t there.
Understanding why this gap persists is key to improving both performance and communication.
The Difference Between Collecting and Connecting
There’s a concept that cuts to the heart of this problem: the difference between collecting dots and connecting them.
Collecting dots is what most traditional learning looks like. Memorize the symbols. Learn the rules. Know the difference between a datum and a datum feature. Check the box, pass the test, move on.
Connecting dots is something different. It’s understanding the why and the when. How does this tolerance interact with that feature? What happens at assembly if I call this out wrong? How do I look at a drawing and know whether the designer communicated their intent clearly, or whether it’s going to cause problems on the shop floor?
Seth Godin put it plainly:
The ability to connect the dots is rare, prized, and valuable… Why then, do we spend so much time collecting dots instead?
It’s a fair question. And it’s one the GD&T training world needs to take seriously.
The Piano Problem
Think about learning to play piano. You could look up an E-flat minor chord in about ten seconds. The notes are right there. Free, accessible, accurate information.
But knowing which notes make up a chord isn’t the same as being able to play music. A good teacher doesn’t just hand you a chord chart. They show you how that chord fits into a progression, how it moves the music forward. They build context around the information, so it stops being a fact and starts being a skill.
GD&T works the same way. Knowing the rules is the chord chart. Understanding how to apply them—that’s learning to play.
Why GD&T Is Especially Hard to Just “Look Up”
GD&T is inherently geometric and spatial. You can’t just read about it and expect it to land. You need to see how a tolerance zone behaves in three dimensions, applied to a real part with real constraints.
Here’s where it goes wrong in practice: an engineer specifies a position tolerance that technically follows the standard. The drawing passes review. But the datum reference frame wasn’t set up to reflect how the part actually functions. So, when inspection sets it up differently than the machinist did, the part fails. The drawing was “correct.” The communication wasn’t.
That’s the gap. GD&T lives at the intersection of design, manufacturing, and inspection. When someone applies a control that follows the rules but misses the functional intent, you get scrapped parts, rework, failed inspections, and weeks of back-and-forth that nobody budgeted for.
You don’t fix that with a symbol glossary. You fix it with training built around real problems.
What “Connecting the Dots” Actually Looks Like
Good training doesn’t just explain the rules. It shows how they play out in real situations.
Instead of abstract examples, you’re working through real manufacturing scenarios. The same kinds of drawings, tolerance decisions, and trade-offs you deal with on the job.
So instead of just learning what a tolerance means, you start to see:
  • How the tolerance value impacts function, fit, and cost
  • What it’s actually telling manufacturing and inspection
  • Where it breaks down when the communication isn’t clear
The goal isn’t just to fill your head with more information. It’s better decisions.
Collecting vs Connecting - GD&T training review
Are You Collecting or Connecting?
If GD&T has ever felt frustrating or hard to apply, even after training, you’re not alone.
Most people weren’t taught wrong. They were taught incompletely. The information isn’t the hard part. Application is. And application takes more than facts. It takes understanding how the dots connect.
That’s the gap we focus on closing. Not just teaching the rules but helping you actually use them on real drawings and real parts.
Ready to start connecting? Explore our training options.
