LMC symbol svgThe Least Material Condition Modifier is a symbol that utilizes actual size of a feature relative to the Least Material Condition (LMC) of the feature to modify and assign additional tolerance to a geometric control. The LMC is the condition of a feature where the least amount of material (volume/size) exists within its dimensional size tolerance.
LMC modifier is placed after the tolerance value and any other modifiers in the feature control frame
Least Material Condition Definition
In order to first understand the Least Material Condition Modifier, it’s important to first understand what the Least Material Condition is. All features of size have a least material condition. In fact, those same features also have a maximum material condition. The maximum material condition, MMC, is the condition of a feature where the maximum amount of material (volume/size) exists within its dimensional size tolerance. Conversely the LMC is the condition of a feature where the least amount of material exists.
Internal and External Features fig 2
The MMC of internal features will be the smallest size allowed by the dimension and associated size tolerance. The LMC of internal features will be the largest size allowed by the associated size tolerance.
The MMC of external features will be the largest size allowed by the dimension and associated size tolerance. The LMC of external features will be the smallest size allowed by the associated size tolerance.
If you want to ensure that two features on a part don’t begin to overlap each other and create minimum wall thicknesses that cause structural issues, the LMC is a good size to pay attention to.
Bonus Tolerances
There is some magic that happens when we apply the LMC Modifer to a feature control frame. The LMC modifier changes the make up of a feature control frame and literally changes the interpretation.
Feature control frame comparison with LMC modifier
Assuming this is applied to a weight reducing hole like we show on the flywheel example below, the LMC for both callouts is 1.755 and the MMC is 1.745. However, they are not the same callouts. The addition of the modifier will do exactly that. It modifies the Ø0.010 value depending on what the feature ACTUALLY measures. If the feature measures AT LMC, or in other words, it measures at 1.755 for this example, you get Ø0.010 position tolerance. You will always get that. However, if the hole measures at 1.745 ,which is smaller than the LMC, you get more room to deviate functionally without affecting a minimum wall thickness. Therefore, you are allowed more tolerance. In that instance, the 0.010 is modified by the exact amount that the hole deviated from the LMC of the feature. This is informally referred to as bonus tolerance.
You are directly trading size for position/orientation. This means that if you make a pin or a boss larger, you have more material and thus can have more location/orientation deviation without worrying about min wall thicknesses. And for an internal feature like a hole, if you make the hole smaller you also get more bonus for yourself. This bonus can be added to the GD&T tolerance and would increase the geometric tolerance.
Bonus Tolerance = Difference between MMC & Actual measurement
Please note that this symbol is rarely used because it applies bonus geometric tolerance when a hole gets smaller, which is the EXACT OPPOSITE of what a clearance hole for a fastener or a hole that is clearing another component would functionally need. In those instances, consider the MMC modifier instead.
The GD&T Symbols where Least Material Condition can be applied are:
Visualizing the Math and the Boundaries
Let’s use this simple assembly and drawing to demonstrate the bonus tolerances and use case for the least material condition modifier. The drawing below is of a simple flywheel. The pattern of 8 thru holes ARE NOT for fasteners but rather purely weight reduction holes.
flywheel example using the LMC modifier
We will allow a certain amount of size variations on the thru holes via the size dimension/tolerance. We will also allow a certain amount of location/orientation for the thru holes relative to the datums via the position tolerance.
This interactive tool lets you see for yourself how the size of the hole will affect how much position tolerance the hole can have functionally. Toggle the LMC modifier on and off to see that when it’s off, regardless of the features size, the tolerance zone never changes. But with the LMC modifier applied, the tolerance zone grows due to the bonus tolerance being added.
You can see firsthand that when the hole gets a bit smaller, the hole can deviate a bit more as well and still be functional, meaning it maintains a min wall thickness to the outside diameter as well as the adjacent holes.
Additionally, there is a “Outer Boundary” button that will toggle the worst-case boundary of the feature. You will notice that this is only available when the LMC modifier is applied. That is because the LMC modifier is a tool that creates constant boundary worst case that can be used to calculate worst case min wall thicknesses.
When there is not a call out to Least Material Condition, the part by default is measured regardless of feature size (RFS). This means there is no bonus tolerance, and the envelope of the part is not defined and the worst-case envelope changes based on the size of the feature.
All Symbols
