Orthographic views allow us to represent a 3D object in 2D on a drawing. Orthographic views can show us an object viewed from each direction. How the views are laid out on a drawing depends on whether 3rd angle or 1st angle projection is being used. You can tell which angle projection is used by the symbol shown on the drawing.
Third Angle Projection
Third angle projection can be visualized by “unfolding the box,” as if the object itself is being unfolded to show the views from each side. Figure 1 shows the views of a cube being represented by third angle projection.
Third Angle Projection Views
Figure 1: Third Angle Projection Views
Third angle views are intuitive, as they represent you looking at the object from the corresponding side. The front view is always shown in the center. The view of the object from the right is shown to the right of the front view, the view of the object from the left is shown to the left of the front view, and the top and bottom views are shown above and below the front view, respectively. If we needed to show the view from the back, the back view would be placed below the bottom view.
Quick Note on representation of the symbol for third angle. There are actually four ways Third Angle Projection can be represented on a print and all of them are acceptable (figure 2). The big takeaway here is it does not matter if the “side” view of the “cone” is on the right or left. For Third Angle Projection the “pointy” end of the side view of the cone in the symbol is always pointing towards the front/”circle” as shown in Figure 2 below. All four of these are perfectly acceptable for third angle:
Third ANGLE PROJECTION SYMBOL PLUG SYMBOL ALL ORIENTATIONS 1
Figure 2: Acceptable Representations of Third Angle Projection Symbol
First Angle Projection
First angle views are less intuitive. They can be visualized by “tipping the box over.” Figure 2 shows the views of a cube being represented by first angle projection.
First Angle Projection Views
Figure 3: First Angle Projection Views
The front view is shown in the center, just like in the third angle projection. To place the view of the right side, you must tip the box so that the right side is facing you. To do this, the box must be tipped toward the left. This results in the right-side view of the object being located on the left side of the front view.  With the front side facing you once more, tip the box to the right, and you will have the left side facing you. So, the left-side view will be located to the right of the front view. This same method is used for top and bottom views. With the front of the object facing you, tip the cube downward. You now have the top side facing you, with the top view being located under the front view on the drawing. By tipping the front view upward, the bottom view of the object is facing you, with the bottom view located above the front view.
Again there is common confusion about the symbol representation for First Angle Project.  There are four ways First Angle Projection can be represented on a print (Figure 4) and all of them are acceptable. The big takeaway here is it does not matter if the “side” view of the “cone” is on the right or left. For First Angle, the “pointy” end of the side view of the cone in the symbol is always pointing away from the front/”circle” as shown in Figure 4 below. All four of these are perfectly acceptable for First Angle.
First ANGLE PROJECTION SYMBOL PLUG SYMBOL ALL ORIENTATIONS 2
Figure 4: Acceptable Representations of First Angle Projection Symbol
Third Angle vs. First Angle Orthographic Views
As you can see from Figures 1 and 2, first and third angle orthographic views are opposite in where the placement of each side’s projection view is located on a drawing. If a person is not aware of which angle projection is being used on the drawing, it can cause a lot of confusion. It is important to remember to look for the projection symbol and understand whether the symbol refers to third or first projection views.
To help you remember which symbol belongs to which view, let’s look at the symbol for each. The third angle symbol is shown at the top left of Figure 1. The first angle symbol is shown at the top left of Figure 2.
Each symbol represents the views of a cone from that angle view. Both third and first angle symbols show the circular top view of a cone and the right view of the cone. The difference in symbols is where the right view of the cone is located.
The third angle symbol is shown in Figure 1. It is represented by the circular top view of the cone with the right view of the cone to the right of it. In the right-side view, the narrow end of the cone is pointed towards the top view.
The first angle symbol shown in Figure 2 has the circular top view of the cone with the right view of the cone to the left of it. The narrow end of the cone is pointed away from the top view. By paying attention to the direction the cone is facing, you see that it can’t be a left view of a third angle projection because the narrow end of the cone would be pointing towards the circular top view. By looking at the shape of the cone, you see that it must be the right view of the cone. Because the right view is located on the left side, you are looking at first angle projection.
As you can see, third and first angle projections show the same information on a drawing but oppositely locate an object’s views. Paying close attention to the view symbol will prevent much confusion when reading a drawing!
Looking for a handy chart to help you with orthographic views?
Download our FREE orthographic views wall chart today.
Download FREE Wall Chart
